576 xpg Auto tune
Kenny
  • Replies 21
After trying the 576xpg autotune i can report back it is a very good saw! Its running a 20" & flys through the wood starts no problem, cold, hot & inbetween. Doesnt really seem very heavy when using either so no complains here!!
Picked up my 576XP (standard) from Jonesie a couple of weeks ago now and loving it. :thumbup1:
For normal fir stuff I just can't fault the 346xp for handling when it comes to snedding quick, but once onto the bigger cherry that I was dealing with, the 576 just chewed it up and spat it out.
Fab saw. Don't find it too heavy and it's a nice shape for throwing around when de-limbing.
Running an 18" bar, with a 24" in reserve.
good saw loadsa power although ours has a small problem now and then with the idle speed,sometimes get a wee bit of chain creep,also when cutting rings accross grain (stringy shavings) if you get any shavings at all awround the drive sprocket,it stalls outright,not sure y?
the only saw i own that does this and the only saw with AT.
other than than a good saw,but never as good as a 372xp ;)
