green mech 1928, how far does it throw the wood chip
timb
how well does a Greenmech 1928 throw wood chip into the truck
Will this machine fill the back of a 7.5tn lorry aswell as a timberwolf190 would.
The timberwolf has fans that can be replace, does the green mech work on a similar replaceable system?
Don't know about conifer but small hardwood enough to knock the flashing beacon off a transit cab :-)
These later ones combine the engine cooling flow with the chipper disc flow.
Never seen a timberwolf nor looked at the greenmech fans.
You are unlikely to damage a 1928 rotor ever unless you put a BIG piece of steel through - we've chipped a couple of thick pieces of re-bar, a Karabiner and a pulley with ours (not all on the same day) and all that happens is the blades get chipped. They are very very solid - you will never bend the fan blades (the machine would stall first I reckon). They throw everything you put in them a long way (not like the old Greenmechs) but probably not as far as the Timberwolf to be fair. They'll easily fill a 7.5 tonner, and you won't need to sned anywhere near as much as you would with the 190. If you're offered a 1928 please let me know as I've just had one stolen.
