Pythagorus therum
80 squared - 20 squared = the distance from the point of the triangle to half way along the 40 meter length = 77.46m (approx 78m)
Now calculate the number of trees in a 78m line = 39 trees and there would be 10 lines in a 20m rectangle giving 390 trees in total
If each side is 80m & one is 40m then the land forms an isosceles triangle.
The area of an isosceles triangle is half base * height - but the height is not 80m!
To calculate the height you need to drop a line from tip to base & use C=A/H from SOHCAHTOA so Cos(some angle) = 20/80 or .25
So use ACos of .25 = 75.5224878 degrees as the angle at each side of triangle
The height can be calculated by ATan 75.5224878 = O/A or
A Tan 75.5224878 = 3.87298334
3.87298334 * 20 = 77.4596668 lets say 77.5
so the land area is actually (40 * 77.5)/2 = 1550 sq meters
= reaches for coat - asbestos one to protect from flames - but it looks right to me!
But he didn't ask for the area?????
Pythagorus therum
correct.:thumbup1:
Pythagorus therum
correct :thumbup:
