I only want 1
2 would be a bonus
but seen as millions have been cut up may be the reason no one local seems to have 1
  • Replies 42
How many millions did you steal?
This will be the last time i reply to you as it seems your are out for a online fight to prove your better then myself. and its not realy a forum for that is it, maybe post like this are the reson behind post's as "Is the recession hitting you hard? " Ill be the bigger man and walk away.
BACK TO OP. You tryed going to speedy hire , they sell alot of gass ?
No mate, I just got a whiff of bovine and followed my nose, come back, I promise I will stop pointing at it.
i have done millions.
go to the tip and ask them for one out of the cages. Thats what I did at Meltham tip and they were happy to oblige
Tried that yesterday and no joy at all
2 of them in the cage:thumbdown:
I make quite a few Chimineas out of old gas bottles. To cut them safely you have to remove the brass valve on the top then fill them with water, as the water level rises in the cylinder it displaces any gas residue. You SHOULD NOT just take the valve off and start cutting as the gas is heavier than air so there will be some left in the bottom of the cylinder even if it appears to be empty.
