Buying a Generator; 110v but want 240v ???
TimberCutterDartmoor
I have my eyes on a Honda genny; the december deal is on 110v models only! Is it fine to use a step-up transformer as follows with this genny?:
:: 3.5kW (4.4kVA) Petrol Powered Generator
Defender 3.3kVA Dual Outlet 110v to 240v Portable Step Up Transformer E203030 at Toolbay Direct
Thanks in advance.
Thanks in advance.
id have thought so,think you lose half the k though? Genset Steves the one for this!!
Thanks in advance.[/quote
u not have any 110v tools?
Just a quick post I can get deeper and more boring if required.
I would just get a 240/110v as the transformer will be a pita to cart about. Also that tranny is only good for 1.6 kw so if you try to boil a kettle will be in melt down before you get your tea. A eu set with genuine honda engine is a good move. Most kettles now are 3kw so 3.5 kw would be a good move.
Generators tend to be 4 wire or 12 wire. John I suspect yours was 12 wire you can get 3 lots of single phase from any 3 ph genset balanced up to the max out put. If you buy a 4 wire set in future it cant be rewired 3 phase. But your 12 wire set could be rewired to get just 1 lot of single ph but will be down rated to 60% output.
Thats the simple version :thumbup1:
