If I understand that correctly I think you need to tend the RW before you sit in your harness. I do this with my thumb because one hand is already sliding the hitch up my rope.
In other words: I stand up on the Pantin, slide the hitch with left hand, slide that hand up so my thumb goes under the RW and pushes it up, sit in harness.
Hope that helps.
I dont like the sit stand method for long ascents, i find the because the wrench doesn't engage fully my hitch is seriously hard to move and often the wrench rests on top of the hitch as the wrench has titled to far downwards
On long ascents are you using a pantin? I just lift the RW up in those cases as the pantin holds the line taught enough for me to ascend the line. Also if you hitch is biting too hard it might be your hitch being too strong thats the hindrance?
Just a few thoughts off the top of my head.
The sit, stand method works fine if your hitch is nice and short to minimise sit back.
For long ascents I pop my hand ascender and foot loop on.
Remember, SRT is not a perfect effort free solution but used correctly its more efficient than DRT.
I am using a pantin at all times with the Rw depending on the situation may add a hand ascender and footloop, i don't like sit standing as i find this slow, i use a spliced piece of cover to advance the wrench my issue isn't ascending it more the fact that when i stop the wrench won't be sitting in the correct position i have stiff thether as i want it to engage as soon as i sit back, my point about the hitch is due to when the Rw doesnt engage all my weight is obviously on the hitch and the Rw is touching the top of the thether as the Rw as moved incorrectly so disengaging is hard and there isn't allot of room to get my hand in there, i have tied a short hitch also.
Sent from my GT-I9300T using Tapatalk 2
Would this help?? If ive understood your problem Ewan?
I whipped a bulge just bellow the wrench on the eye which stops the wrench dropping. Pretty simple solution.
