It's not perfect but it works, it's a stepping stone! You get a little friction when it pushes against the rw but with a little cut out on the pipe I think it will be better.
Cool that the rw will almost be in set mode as you sit in it too. I like it, great seeing new ideas form
Exactly! Hopefully someone else can put there stamp on it and help it evolve.
Great thanks for sharing.
I ahve some plastic spiral hydraulic hose wrap that
should work.
Do you have the bolt gapped wide open?
How are you finding the friction if it is.
I ahve mine gapped tight and find the friction is just right at 210lbs all suited up.
