felling leaning trees
richyrich
after just reading a thread on trees barber chairing, etc. - a technique i use on felling big leaners or sometimes big limbs (that you're supposed to do in bits)
with trees first i take the gob out- nice and steep to avoid hinge snapping, then instead of boring backwards on the felling cut and leaving back intact. what i do is 2 separate back cuts at approx 45 degrees to the proposed hinge.
this leaves a triangular hinge.
keep cutting either/both back cuts making the triangle shallower until the tree goes- the tree should hopefully fall in a controlled manner (does not work so well for boughs).
not sure if this is a recognised technique?
just my method- i have tried back cutting with willows etc and saw sometimes would get stuck as the trees fibres twisted.
Sounds like an interesting method , could you post some pictures of each cut and some pics of the hinge once you have felled the tree ?
i won't be felling owt for a while but will do if something suitable crops up. its ok method for dropping big limbs- seems to avoid splitting to a certain extent ( ok for silkys ).
i did drop a big crack willow and it fell in slow motion- suppose the hinge was pulling fibres up the trunk rather than working like a conventional hinge
What's wrong with a nice quick back cut? Powerful saw and small bar. I dropped a number of leaning willows on a site clearance with a conventional back cut. There must have been 25 degree lean on some. 660 and 20" bar with sharp sharp chain, the cut is done before the tree starts to quiver!
I can see the methodology in your method, although I prefer to use the bore and release.
the tree should hopefully fall in a controlled manner (does not work so well for boughs)..
that doesnt sound very reassuring:001_rolleyes:
If your saw is getting jammed i dont think you are doing it right.
triangular cuts,sounds like all you are doing is leaving a very thin hinge perpendicular to the felling cut.
:confused1:
