I am very impressed with it, had it out this morning on trial.
Got some 8ft high Leylandii hedge put to one side to throw through it which was limby and busy on the top and it played with it, where my 65xp would not have taken it through, this did.
Feed speed is just as fast as my old bandit and can be adjusted slower if required, a feature I like.
The 75 has a few features different to the 65 which again is a big advantage.
The feed wheels are a lot closer to the flywheel so leylandii doesn't "wrap" as easily.
It has moved to a Kubota 45hp turbo'd engine rather than the Deutz 35hp non turbo, much more grunt now.
It has huge flywheel bearings, twice the size of the 65
It has a drive dis-engagement clutch
It has an engine cover and is a LOT quieter
Access for servicing is dead easy.
The only bad points I found was the discharge chute needs extending ( something bandit should be addressing by now) because over spray of chip and dust.
No locking tow hitch is the other big issue. If you are laying out the same money you could buy a quality new car for, you'd expect some sort of security device.
I was pleasantly suprised with it's performance though, better than I expected.
  • Replies 30
It weighs near the same as my 65xl and will tow the same which is good
Price approx 21-22k including
Sorry Carl, I can't believe I didn't take more pics.
One big change is the top feed wheel carriage, which is now hinged at the back instead of front, which will create down force on the top feed roller as it feeds in
Sorry mate....I think he said they were 1340
Probably, I just googled it and took a flyer. Nice chipper, is that a landy pulling it? I don't want to get into a towing thread (yawn) but in the long run would it be more worthy of a larger lorry?
