Really? , i guess we must be a bit more fortunate down here , so are you expected to re-plant in the situation of removing a TPO'd tree that has been blown over in a storm ??
From the 'Blue Book':
11.8 The Courts have not resolved whether there is a duty to replace trees uprooted or
destroyed in strong winds. The Secretary of State considers that the duty does apply in
such cases, although the LPA may decide not to enforce the duty depending on the
circumstances of the case.
  • Replies 45
:001_huh: So you don't notify??
DDD, is Dead, Dying or Dangerous, so you still need to notify.
"11.9 Anyone proposing to remove a tree on the grounds that it is dead, dying or has
become dangerous is advised to give the LPA five days' notice before carrying out the
work, except in an emergency. The LPA have powers to dispense with the duty to plant a
replacement tree,138 and any request for such a dispensation should be put to the LPA in
writing."
I think it's advisable but not necessarily a requirement. I would always notify to cover yourself though.
Cool Beans thanks for that :thumbup:
so what is the bluebook view on dead trees being "exempt" from planning is my TO correct ? :confused1:
work, except in an emergency. The LPA have powers to dispense with the duty to plant areplacement tree,138 and any request for such a dispensation should be put to the LPA in
writing."
So there is a requirement to replace, unless the LPA wave it.
"6.2 The LPA's consent is not required for cutting down or carrying out work on trees which
are dead or dying or have become dangerous.62 In the Secretary of State's view, this
exemption allows the removal of dead wood from a tree or the removal of dangerous
branches from an otherwise sound tree. If a tree outside a woodland is removed under this
exemption section 206 of the Act places the landowner under a duty to plant a replacement
tree at the same place (for more guidance on the duty to replace trees see Chapter 11 of
this Guide)."
Beware though - I would always double check on dead-wooding. Imagine a TO's horror if some idiot removed all the dead wood from a notable veteran tree....
Edited by Paul Barton
Adding note re dead wood
11.0 deals with trees removed in contravention. There is a duty to replace a tree if you didn’t have consent to fell.
DDD is an implied consent so no duty arises as long as your call was good.
The LA can however issue a TRO if they see fit.
