cubic meters
chepo
  • Replies 20
Length x width x height will give you the m2. Then the bit at the back of the trailer would be length x width x height divided by 2 to give you the area of the triangle shaped bit left. Then if you take the triangle shaped piece off 1st amount that will give you the overall amount
You've lost me anyway!
I use an IFW GD85, 8 x 5 foot. I load it with a 2 cubic meter bulk grain bucket on a teleporter.
I can just get a full bucket onto the trailer, the load is ridged up along the center. I then sheet it and cover the sheet with an elastic net to stop bits falling off and possably damaging other cars etc.
A
