looked at this job and instantly thought i hope it just winches off otherwise will be a right pig of a job.
so step 1 cut stem
step 2 felling lever a gap to get a sling in
step 3 winch off
step 4 roll over and cut into thin strips
step 5 stick the strips through the chipper
step 6 go to the pub :thumbup:
you've made that look well easy!:thumbup1:
Satelite dish has moved a bit though....:sneaky2:
with this job i knew i didnt have to worry about the dish as its a house being turned into a childrens home i do alot of work for them all over the county, so they just bought this house and renovating it into there needs. but it is worth knowing to make sure its clear around objects first :blushing:
