It is unusual for the big end to go - only seen one go! These blowers have a cast shroud around the flywheel and the bolts can come loose and clout the flywheel back side - worth checking other than that, worth checking the crank bearings - guess there is quite a load on the impeller side!
Thanks spud, it's defo not a loose screw I have seen that a few times also, there is play when you pull/ push the con rod, never thought of crank bearings :001_rolleyes:
Dodgy crank bearings tend to give a hollow dry rumbling sound, once you have heard one go, you will know the sound forever!
Big ends tend to thump - if you look at the piston through the exhaust port and rotate the crank to and forth, the crank will move but the piston won't if the ends have gone!
I am right, when you gently turn the flywheel back and forth you can feel the play and hear the gap tick tick tick :001_smile:
+1, a buggered big end makes a right noise, similar to kicking a saw over with no muffler, only angrier
Don't write off the crank bearings - strip it down and check the bearings by holding the crank end and moving it up and down and side to side - there should be negligible play!
The bearings on the IPL look like ball races and they usually have no play if they are in good fetttle - easy job to strip the unit and check!
Well, whilst I've come to the conclusion that the Germans are a very anal and precise nation (order anything labeled assembly and you will see!), the Swedish are completely mental! I ordered a crankcase assembly labeled as 'complete', this turned out to be 2 crankcase halves, bearings (fitted), ONE oil seal (fitted), locating lug for the chainbrake (fitted), bar studs (fitted), chain oil breather (fitted), ring for the brake arm (fitted), 3 screws for a generator (XPG), 2 casing lugs and the holder for the spring that stops the brake arm flopping around. This doesn't sound very complete, it doesn't make much sense either!
Sounds pretty complete to me, what else did you expect? there are short blocks available for certain models, called short blocks
Bolts for the case, a gasket maybe? Another oil seal? You know, stuff to make it complete!
Sounds like a Friday afternoon car in chainsaw form.
