there u go ben
was thinking about taking the danarm 1-71-ss but 4 saws is just to many
Thats a big one Martin and the bar is quite long as well:lol:
Thats it - bed beckons
Just finished the muffler mod on the 357XP, it is the shotgun outlet that looks quite nice IMO, fired up the saw and wow - loud indoors, very responsive on the throttle and 190psi compression measured but expect this to drop to 180psi once the oil in the bore has burnt off.
Idle is fine - this is just on factory settings at the moment - just need to put the clutch etc on the saw - came up pretty clean in the end and looks and sounds great.
Getting near the 30K views mark on this thread - must be doing something right:thumbup:
Just wanted to say a big thanks to all contributors to this thread - been very interesting and informative for a newby amateur like me :thumbup:
Just by way of a little diversion that may be of interest to the engineering types here, heres a little something I was sent a while ago from a collegue..........
and no, this is definitely not on my bench
[ATTACH]90669[/ATTACH]
That must be an engine out of a ship?
Spot on again Spud.
When I said little though I meant it as pictured is the 6 cylinder, but they go up to 14 cylinder.
Got some statistics on it, but the numbers are just ridiculous. :laugh1:
spud, any ideas why the 357 seem to leak oil even when not running, i have stripped mine down and cant find a fault and seems to be a common problem from my experience anyway
mine does same so interested in this
I have seen the chain adjuster wear a hole in the side of the oil tank before - I thoroughly cleaned the area and repaired with JB weld. Other than that, it may be the compression fit of the oil pipe between the crank case and the stainless cover - is the small foam pad still on the top of the pipe union?
