base layers
Steve Bullman
  • Replies 23
Helly every day! Smelly helly. I still have some original hellys from the 80's they were itchy and v. smelly but they did the job.
They have a new range for cycling that would be good, extra protection over the buttocks, would fit well under a harness.
They do them in pink Steve so you'll be well happy!
Haven't tried any Helly tops so can't offer a comparison but I have used both man made Regatta X-ert and Smartwool merino, merinos obviously quite a bit dearer but warmer, much better cut and fit with nice long arms, just wear and air, doesn't need washing anywhere near as much as man made stuff and it doesn't stink! (May recoup the cost from not having to wash every time I wear!)
But unlike the Smartwool I won't be too fussed if I wreck one of the Regatta ones and they do a fairly good job for the cost.
The merino's really good, but IME from cycling it does need to be able to wick, if you're working hard and have a shell (even Gore Tex) on top it will hold moisture, in which case its good to have a change.
