Delivering vented bags
Treemon
  • Replies 40
  • 3 months later...
my firewood trailer:
Indespension plant trailer with a hiab fitted to it, 24v electric pump powers it, will lift 3/4 ton. can get six 1/2 m3 bags on if need be. also great for picking up big lumps of wood. looking for some tractor timber tongs for it if anyone knows where to get a decent set?
Even has a little ram for lifting it on and off the truck, which can be used as an outrigger when lifting heavy stuff
its not that heavy really, the plant trailer distributes the weight quite well, certainly no worse than having a mini digger on there
When you have done your deliveries and are running home empty there is an extra 200ish kg between the front wheels and hitch. Most vehicles have a max vertical hitch load of 100kg. Are you telling me you are within these limits?
i do think the the hitches are rated @ more than they say they ,they will have built some leaway in ther somewer :001_tongue:
