chinstrap question
bob
If I have a climbing helmet to en 12492 I am fine up a tree
What should we do when on the ground.
should we change helmet still buckle the chin strap or should it be undone
Thoughts:thumbup:
My mate has just done 30/31 and he was told that you are not supposed to use a helmet with a chinstrap on the ground, dunno if that's right or not but this was from nptc assesor.
i was told u can use climbing helmets on the ground, he had a petzl vertex vent like me,
Just undo the chinstrap on the ground. If its undone it is no longer serving as a chinstrap, if its a real issue, tuck it up inside the webbing out of the way.
Thats what i do.
I'm not sure if there is a real answer. I've been told your not supose to wear a Vertex on the ground by a NPTC assessor. Although i've had many assessments where they've worn them.
