Hello,
I'm about to buy my first chainsaw for cutting up firewood. I've done a little research on google and this forum and the 346xp seems like a good choice.
Which bar length/chain should i go for and does anyone have any recommendations on where to buy?
I'll be felling small trees, cutting rounds and old pallets etc up in Perth, Scotland.
Edited by hippytyre
  • Replies 27
try and buy just a 346xpg powerhead then fit a 13" oregon microlite pro bar, with oregon 95vpx multicut chain, and an 8pin drive sproket I can cut stuff upto 18" inches as fast with this set up as i can with my 372xp
with the heated handles charlie:001_tt2:
and "girly start" :001_tt2::blushing:
I should add the multicut chain is better for dirty timber and whilst i have only used it for a couple of days its miles better than the standard stuff if your cutting timber with and debris in it
just out of interest why if your cutting up pallets and felling small trees do you want an 18" bar? if your cutting 18" timber mostly then look for a bigger saw. If you not get a smaller bar, most the stuff i fell is 15"+ diameter but this is more than made up with the speed the saw can pull the smaller bar (13") at. If you order the saw you will get a chain with it so dont worry about that.
the 18" bar doesnt balance that nicely on the 346xp IMO as its the top end of bar sizes recommended, 13 -15" are fine
