46 with a 20inch bar???
big fell!
i run mine on a 25", runs very nice. Anyone run theirs with 30" or higher? Need something with a bigger bar but can't afford a bigger saw yet :(
I run an 044 with a 36in bar when my 066M is sick. If you look at the older catalogues they suggest a 32in max for the 044 and 046, so I reckon it's OK if you take it gently and don't expect the same cutting speed as you would with a bigger saw (or a shorter bar). I do take care to sharpen more often and probably leave the rakers a bit higher, to avoid stressing the engine. I wouldn't want to do it too often though - too slow for pleasure.
Alec
