2 100ft pines, small garden, speedline and heavy rigging
gibbon
  • Replies 44
great vid:thumbup:
how do you set up your rigging/speedline system?
is it easy to do/use?
Its pretty easy, but only the 3rd I've done so not sure if its right. Tied the speedline off at the top with a bowline and ran it to a high pulley in the other tree down to a grcs. Control line set up as normal with a capstan. We kept the speedline loose and one guy let the speedline pull slack trough the grcs as bits fell as the other ran out the capstan. Once the pieces were stable he then tightened the speedline on the grcs. It all worked a treat. Had a 80ft stem rigged down by breakfast monday, set up the speedline and had the other tree stripped out by 3 the same day.
I had a problem this.time.with music. I think I filmed.one.vid in mov and had to down load a free converter to change it to avi. Took ages it did
Have you got a link for the converter? First one I found leave a "demo only" print on the film.
Good video though BTW! I cant watch it in HD on my old computer and I am filming in SD for a while until I up grade.
