with the new one out in june and everybody flocking to buy it i will wait and pick up 200t's a bit cheaper so they can clear old stock
The thing is, i don't think they will have any left by then. But if there are you may find them going for even more than a new one
  • Replies 47
I always wondered what they are for?
Not being funny but you usually dont see them on pro saws just the semi-pro or hedge trimmers. Even then a never need to use them!
alot of pro huskys have them
yh i suppose, to be honest i like the primer, just ive never seen one on a stihl chainsaw befor,
The MS192T also has a fuel primer
Yes but WHY?
What purpose do they serve????
All i can see what they do is manually pump fuel from the tank to the saw.
Carbs have done this on their own for years.
Well, the PRO Stihl FS-130 (and KM-130) brush cutter 4-mix engine also uses a fuel primer, so even Stihl already use them for pro-range products.
But why they choose to fill the carb fuel chamber using a primer pump, I don't know. Possibly it saves a few pulls when starting cold, so you don't have to have the carb membrane suck-in the fuel.
