Its something to do with the rope getting picked/snagged/ruined in a crotch. I have done it with 1/2 inch yale and it seems ok, that was until the mexican burnt it by lowering a lump too quickly haha :)
  • Replies 28
The friction on the branch means the core and outer can move differently. Not so much of an issue with a climbing line but the effect still happens.
A double braid is really two ropes, one inside the other. In a situation with little or no friction to the outer cover, the load is shared equally between cover and core.
When there is friction from rubbing on a branch the cover takes most of the load, so the rope is not as strong as it should be, and are susceptable to damage from glazing and picking.
Additionally, double braids are expensive ropes and ruining them by running them over crotches is a bit of a waste of money.
agreed
And Double braid rigging is not a solid rope which allows it to flatten out on on portawraps ect so aids in grip and heat dissapation
What kind of weight are you after.
I would either say 13mm XTC or sirius which i know treeworker sells
Mostly use double estelon 9/16 and 5/8,all rigged on pulleys/blocks
also have smaller braided lines
have just aquired some 5/8 Yale polydyne
  • 4 months later...
how does polydyne hold up? its one that has caught my eye but have never used it myself.
For negative rigging its the way to go....not only do the stats speak volumes but in reality blocking down big wood even feels much less severe. A 60m length needs milking like you wouldn't believe though!
