2 hours ago, Stubby said:
I have a 20m of angle 34mm for my .308 but not tried it yet . How far out do you recommend before befitting from using it ? 800yds or more ?
Morning Stubby, I know you directed that at Gareth but if I may 😌,  in my case I wanted to use a picatinny rail to mount the scope so thought why not 🤷‍♂️. It’s not gonna hit the range much but I’d like to stretch out a bit more than the normal stalking ranges ( I’m no fan of taking long shots on deer or any creature ) if the chance arises, hence sticking on the 20moa rail, I’d say you are on the mark with 800 yards ish, a plus for me is the 20moa is 20 less to dial in as let’s face it the 308 has a fairly looping trajectory compared to some of the new tack driver calibres. I do miss having the opportunity to shoot competitions including PR where 600-1000m was often a start distance, just never seem to have time nowadays as let’s face it shooting is a fairly selfish sport.
I did leave it for @Johnsond, those sorts of distances are a bit outside my acres.
I actually checked two of my longest fields together maxed at 600yards to the barbwire 🙂.
Gareth the best shooting I do by far is 22lr subsonic pest work, or messing around at 150-200m with the same calibre. Good fun zero noise issues and hones your skills just the same. Cheap too.
I have HMR & LR with an empty slot for 556, but in all honesty 90% of the time I use the FAC 22 air rifle.
Dirt cheap, quiet, bloody accurate to 80m and almost identical to the standard air rifle if noticed by walkers.
I'd never say I don't need the bigger stuff, had wanted to get more into foxes but earning a living and farming doesn't leave much time for sleep or foxing.
Something I didn't know ( but you guys probably did ) Is that the .303 Lee-Enfield No4 T . was sorted from different batches to pick the best performing ones strait out of the box . They were then sent to Holland and Holland to be made into top spec sniper rifles . The scope that was fitted  ( No 32 telescope ) shared the serial number of the rifle so that they always kept together . If you can find a genuine one they are worth a lot of dosh . A lot of fakes out there though .
You been watching bloke on the range ?
In a book by Steve Houghton . The British Sniper : A century of evolution .
Ah yeah, think Ian McCollum talked about it a while back and Jonathan Ferguson.
Isn't that the book with a good section on the beginnings of Accuracy International?.
It started in a shed, is supposedly a great read.
Edited by GarethM
Headlines say £400, that's before any lead banning etc.
Hopefully they'll extend the period but not holding my breath, hows the airgun thing work in Scotland as they're all fac aren't they ?.
