Jerky
Nick Waring
  • Replies 28
Alton Brown on Good Eats made some once. Looked cracking stuff. Had a go with the oven on low but low wasn't quite low enough. Turned out crispier than a Findus Pancake. Apparently I should have turned the oven off when it reached 50 degrees then banged the meat in and left the door cracked. Keen to find out what method you use and how it turns out.
Sent using Arbtalk Mobile App
Still a bit soft for my liking, was 30 -40 cm away from the stove from about 7pm
Am a little bit dissapointed with the chillies it's supposed to be hot enough to stop me nailing it too quickly but that's not gonna happen.
I'll see what it's like when I'm back from work later but I reckon it's gonna need another 1-2 hrs with the stove on
Sent from my iPhone using Tapatalk
Looks yummy!
Tis very yummy thank you very much,though am disappointed with the chilli heat they were dried bought on the bay and are easily eatable not what i was expecting at all. Think for my next batch I'll avoid the commercial sauce and try to make it all myself as not too keen on the stickiness.
Did you have another attempt ?
