How much weight can a 1.8 Escort van tow?
55 1.8 d =475kg
55 1.8td =440kg
75 1.8 d =675kg
75 1.8td =640kg
Are you quoting payload figures ?
I would be expecting the answer to be about 500kg for an unbraked trailer and about 1000kg for a braked trailer.
manufacturers quotes
The 55 model 1.4 efi carries max 452kg.
55 1.8 d =475kg
55 1.8td =440kg
75 1.8 d =675kg
75 1.8td =640kg
As for towing the gtw on the plate tells you the maximum combined weight permissible The vans kerb weights are between 1103 and 1185kg depending on model.
Edited by log supplier
wouldnt be me towing a ton in an escort van, back end would be all over
Years ago my son in law had a wreck of one when he first started out.I met him at his job and dropped some connies for him,not realising that he was going to take them all away.He'd borrowed an enormous bateson trailer and he stacked all this up on it really high.Must have been 2 ton easily.I followed him as a precaution down the lynn bypass doing 30 flat out weaving along on a saturday lunchtime.Luckily he got away with it - happy days.
