Bandit sidewinder stump grinder or equilivent
treefrog
  • Replies 21
I'm a Bandit owner and critic.
For the novice its a big heavy b#@tard that requires alot of attention to level the ground as it becomes dangerous when working otherwise.
Plus sides are many.
I'm 63kg, the machine weighs 350kg. I can move it with little effort.
The power is great, its fast and I can really feel the stump and tooth performance.
Built solidly, starts easily.
Earns me good money.
I reckon it burns 4litres per hour, I use the round green teeth which can last up to 24hours if your lucky though 16 is more reasonable.
I also am pleased to say that Global Engineering who are the importers to the U.K are most professional, customer orientated and just plain good people to deal with.
Well done guys.
Ty
I know not another stump gring thead.
I am looking at getting my first stump grinder. I have used many varieties over the years but like any one want to make the right choice.
I like to look of the bandit side winder but would like to see if any ones used one(opinions please) or got any suggestions for something similar.
I want it to be narrow but powerful to do 70-80% of stumps well.
Whats your thoughts
One of these
http://dl.dropbox.com/u/37434854/P1000322.MOV
Not sure if I am meant to be standing so close to it, oops.
29inches wide. Though it is a bit longer and heavier than the pedestrian equivalent? The teeth have done 7-9hrs in the video and it has the 35hp Vanguard engine.
Jonathan
Jonathon, can you slow the side to side movement of the head and how many rows of teeth does it have? Did you have trouble getting over the arisings in front of the wheels? I used a Carlton 4012 and it couldn't get over the arisings so easily, so thats why I am asking.
You can never stand too close! You have to see what you are doing!
We have a camon for the small ones and a rayco for the bigger or easier to get to stumps.
Most of the hire companies use the camon. It's not self-propelled so can be a bit rugged on the user. It's light so easy to manhandle. With sharp teeth I'll tackle anything with it. Had it six+ years and the old girl is still going. It's had a few new bits and bobs and looks like a six+ year old contractors machine.
The rayco is the 25hp petrol super junior and is a bit of a jesse really. It's a big thing for what it actually does. Had to replace the engine after 1100hrs and the toothed belts go annually given the number of users and the lack of respect it gets. If it's just one user and they have a bit of sense it's a nice machine if not pushed too hard. Bully it into stumps like you would a big diesel hydraulic one and bits break.
Camon<£3000
Rayco approx £10k
For a first machine I'd go camon every time.
Hi Scott,
The side to side can be slowed on a thumb wheel on the machine. I have it on the fastest setting and do it with my fingers. I have a feeling it has 25ish teeth though they are staggered, they are 700 Green teeth and seem to last a while. I will count them tomorrow
There is no issue with it driving over the pile, just that the pile slows the cutter head down loads when you are deep in a cut. Which obviously affects the larger machines much less. Though I feel this is the best compromise between access and productivity.
After putting a few hours on this machine I would also reccomend you get the biggest horse power you can on it. It would be awsome with 50-60 hp but apparently it would tip over too easily (Which I do believe as you have to be cautious on banks)
I never bothered trying any other similar machines out. Though the Carlton is basically the same as the bandit anyway.
Hope this helps
Jonathan
Hi All,
I think I've arrived a little late in this post to make a difference, but better late than never!
We (Orange Plant) are now the importers for the Carlton range of stump grinders. As some of you have mentioned the Carlton is a very effecient stump grinder, and with the Sandvik cutting system it really stands out ahead it's competitors. A deeper sweep means less time; and you all know when it comes to grinding stumps time is money! The Carlton also has the most effective radio remote control system, and really needs to be used to appreciate this.
Please not that the Cartlon is definitely not like a Bandit. The Carlton has a better build quality, and far superior hydraulics. Also the Bandit does not have the Sandvik cutting system :thumbup:
Currently we are offering 0% finance over 2 years, with only a 10% deposit. We have most models in stock.
We are happy to demo our machinery side by side with our competitors. We stock parts, and offer a 24hr delivery service. Please call or email me if you would like further details.
Kind regards,
Lee James
Business Development Manager
Orange Plant
Tel: 0191 2361028
Mob: 07837 087940
Email: [email protected]
Website: Orange Plant | Wood Chipper & Stump Grinder Specialists | Official MainTimberwolf Dealer | Carlton Importer
Twitter: @orangeplantuk
Facebook: 'Orange Plant'
Whats your thoughts
If you want to get through a lot of stumps then I would not go for a swivel type grinder. The problem you will find is when you push the grinder hard the wheels will swivel rather then the cutter head going thorugh the stump! common problem when the teeth get worn or the ground is slippery, JBM had a lot of problems when they brought this type of style out. The best grinder on the market of this size is the Carlton 2010. reasons being, It is 29" wide, has a very strong build quality, has a sandvik cutter head so will cut through stumps with easy without you having to put much effort into trying to swing from side to side, tooth life is measured in 100hrs not no 10's and sharpening is done on the wheel so no need for spanners and down time. also the machine is very low maintenence with only 2 grease points. Oh and it will grind deeper then any other ginder of this type because Carlton had the sense to mount the engine tilted back towards the operator so the engine when at work will not run out of oil like the other grinders out there.:thumbup:
The big plus is back up, I think Carlton is now supported through five outlets in the UK, I heard that Liston and Orange plant have got together so anyone can go to any of those dealer depots for parts and service.
Hope that helps , Good luck.
