  • Replies 55
Here ya go Mark, double-bowline on the bight, with spike, stick or whatever to allow easy untying.
I wonder if a keylock crab inserted in place of the spike in the bowline would leave enough slack in the knot after heavy load is applied. Always have a steel crab lying around when doing rigging.
My old boss used to use them old c hooks in the woods and we used to just use a hitch that was more wrapping the rope rather than using a knot if that makes any sense can't explain how to tie itthough sorry. I would love to get hold of some of the old forestry c hooks if anybody knows where to get hold of any
Lorry, get a blacksmith to make you some up out of old half shafts.
The last ones we had were made like this.
When they were made he cooled them slowly in waste oil rather than water.
I can't remember exactly why, but I think it was to do with the temper or something, to leave them springy rather than hard and brittle.
use a short length of dynaline or tennex spliced both ends (one end big eye & one end little) & tie a klemheist, have pulled this to over 10ton on the rig & still un-ties easy peasy, putting a thimble in the small eye makes it super quick to take your hok out without snagging.
I will try to explain one knot I learnt, don't know the name.
Take a long loop wrap it around once ( or twice if you like).
wind the loop 4 times around the tension side rope, so it looks like a simple wire wound joint.
then tuck the loop doubled up through the start of the wrap, it really is that simple.
The doubled up loops help prevent the rope jamming when under load.
pull lop to release, works well on thick ropes also place a piece of wood put into the start of the wrap so it can be pulled out to ease the loop.
I also found when joining slings a piece of wood jammed inside helps the release. Just saves using shackles on winch lines.
hope this helps
Edited by blazer
This is what I use with a stick etc stuck in the knot if needs be....
Blazer I think means the same.
Never had a knot stuck, used with all winches and easy and no extra kit:thumbup:
When in pic 2 go round back of the 'tree' (as bowline n rabbit) rope, then feed it through the middle of the twists add stick .....jobs a good un
