Why not install the hydraulics and pto? Nigels mog started the same way
Very expensive, far cheaper to buy a Mog with exactly what you want on it from day one.
It is possible to fit a hydralic pump to the top of the gear box.It bolts straight on,you'd have to fit a tank and the valves but its possible.I had a look at a U1850 that a guy is fitting a tipper to,a normal tipping body not the "X" frame type.I can ask him what is going to cost all up.I know the hydralic motor is a high capacity type as the mog had a crane on it before.
There is plenty of room inside the chassis rails for the oil tank,you could stand the deck off a bit to fit the valves out of the way?Or mount them on the side of the tank?
Somthing to think about anyway.It might be nice to have it side tipping,then you wouldn't have to unhook the chipper.
Something i would recomend also- you may want to do future modifications towards ag spec and it makes sense doing it right the first time
