footlocking
atree
  • Replies 26
That last guy goes like a rocket. Frank some one? I've only used the technique about 5 times in the last 5 years, consequently I count my self as a mere mortal. Are most of you guys that are good at it practicing within the work environment or do you do recreational climbing in down time too? I need FL guru I think.
Deer man
The ISA tcc footlock event specifies a doubled line.
Husky King
A pantin is a single toothed cam type ascender that straps to the inside of the left foot. It can be used to ascend a static single line system or to pull slack through a dynamic doubled line climbing system.
Deer man
Husky King
I thought it was designed for the right foot?
Thinking of one myself. I tend to footlock the tail quite a bit, and it would probably make it tonnes easier, but im concerned about its effect on the rope itself
at college we were only shown with the tail. only sic been working have i been shown the proper way the double rope way.much easier. just it requires alot of strength.i find it much easier in trainers than boots not that i climb in trainers at work just when playing at home. just easier to grip the rope in trainers.
Footlocking on douple lines can be (if done right) the quickest and most energy efficient way to access a tree (with out SRT), if you grab 1 meter of rope you climb 1 meter of rope.
Footlocking tail end of the rope you will only climb half the distance, but what ever gets you up the tree I guess. I would only footlock the tail of the rope when I am already in the canopy and the line hangs in free space and you need to ascend.
Secured footlock takes time and practise but when mastered, is a great skill to have.
