More 'find the hinge' than rate it!
Cor you dont 'alf pick 'em dont ya!!
Looks like bit of a mare so top points for that. :thumbup:
(minus two points for the hell of it = 8 points). :thumbup:
cheers, steve
cheers, steve
Twas the last one of the day so no over thinking, no messing around just get it on the deck & hit the pub! ;-)
I don't see how - you can cut the hinge finer as you do not have to compensate for the longer fibres if you think it might be a problem.
On the subject of fibre pull, does the distance of the hinge from the jacking point affect the risk of fibre pull? I imagine the closer the hinge and jacking point are the more chance there is of forcing the tree up rather than forward?
10/10, cutting blind effectively, you couldn't go lower or higher to find holding wood. Nice one, I guess you were happy to see it on the ground :thumbup1:
