anyone used a 10inch Junkari pto chipper
i had a 6" junkari on a mog years ago it was rubbish, i also used the 10" one at a sawmill i worked at, was ok there but it was for chipping slab wood which i think they were designed for.
The problem i found with them (they may have changed the design now) the flywheel was at an angle to the rollers so there was a triangular dead space between the roller and the blades if a knuckle or section got lodged in there it was a pita to get anything past it:thumbdown:
