  • Replies 21
I always thought that a bag was a cube, but then realised that it is (apparently) 90cmx90cmx90cm = .729 of a metre, but I've also seen this size bag described as .9 of a cube - most confusing.
I guess the volume varies in volume if it bulging too!
Anyway, I guess it's just a case of watch out for weights and measures i fyou are advertising volumes
I
First thought:-
As the length of the sides cant increase when bulging in the middle the corners will come in. I am almost positive that the volume will decrease exponentially the more it bulges.
Think of a cardboard box, if you bulge it in one direction the other two sides come in & reduce the volume & if you keep pulling two sides out the other two side meet & you have NO volume at all.
Second thought:-
If the sides are added up on a 0.8m bag they come to 3.2m.
Using Pi to work out the volume if it was a round bag 0.8m high it would be 0.68m3.
So
As the base wont let the bag go round at the base I suspect that reality falls some where in between these examples & the bags volume does not change much when bulging.
So who is up for measuring it using water?
(line it with plastic first)
Here we go again, a customer asked me what size my load of firewood is, i told her 1.5 cubic meters approx, she asked whats a cubic meter?, i then said that it was approx 3 white builders sacks give or take a bit, she said oh a tonne bag, so your load is 3 tonnes? and it goes on and on and on and on.......:lol:
Brilliant! :lol:
