make sure you get the long one
IMO the others are a bit short
IMO better than a normal ring to ring
IMO not as good as a ART ropeguide but a lot more affordable
i really rate it. the friction you gain from one of these over the ropeguide is not worth the money for the Art for me personally. i have a home made x long friction saver with a pulley and the difference is negligable i reckon. i use the multisaver everyday and it is smooth and easy to install and retrieve.
imo the rope guide is worth every penny, the difference in friction is huge
chears guys ill get one one then as it does the same job as the art and the sirrus looks a lot more friendly to use looks a lot simplar and cheaper (:
its cheaper than the rope guide for a reason!
rope guide is worth every sinle penny, simple to install, retreive, spend a little more and get the best
edit, ditto john, diffrence infriction is huge
