Arbtalk fungi guide
Steve Bullman
I had it growing all over some cut beech i had stacked in a corner outside for a while, came to pick them up to move them and i heard a tearing sound, in doing so it was trying to move several pieces at one time that had stuck together. Once i prized them apart, thats what they were covered in! I just scraped it off and its not come back since. Have they been exposed to the weather Saul or been anywhere with excess dampness?
Yes, it was under a drip in the warehouse.
[emoji106]
  • 2 months later...
  • 1 year later...
  • 1 year later...
7 hours ago, treevolution said:
Can anyone help identify this bracket.
Found about 2m high on a beech tree.
Thanks in advance
That’s likely to be Fomes fomentarius but need’s more images to be certain. Ideally when you’re trying to get an ID you need to present images of the top surface as well as the underside and where possible a slice/wedge of the flesh/trama from inside the bracket showing the colour and texture.
Thanks for the reply.
Unfortunately I didn't have a ladder to get up close.
Will have a read up on the bracket to see if it matches and what steps should be taken.
Thanks
