Ride on mower lift for cleaning maintenance etc
J.D
  • Replies 25
Alright folks,
What do you use for working under your ride on mowers etc ?
I've had a mare this weekend working on an Etesia hydro 100 evo, I struggled at first ot get the ffing blades of then managed to wedge a woodruff key in the spindle housing, long story short, the deck came off and I fixed the problem, but it took hours and it was pouring down, sunday wasted and all I could use was the ramp on the back of our van to raise the deck to do the work.
Is there a way of doing this preferably not one that burns a hole in me pocket ?
Cheers all
Hi
You need a clip lift A New portable hydraulic ride on mower/quad lift for ease of maintenance to blades, spindles, belts etc
Available from your Oregon dealer part number 42-086 it can lift up to 300KGs or 660lbs.
It folds flat to store on the wall or in a service van.
Ask any of the large dealers on here they have the info already.
Les
See [ame=http://www.youtube.com/watch?v=4oPMutnGaa4]YouTube - CLIPLIFT AT.MOV[/ame] for a video which shows it work
  • 5 years later...
High enough that I can work under it safely with the flail either attached or detached.
Could you weld up two rsj/universal beams to act as a ramp for it? The tracks would fit nicely between the channels making it hard to track off. Taper it at one end so you drive straight on, rising to 50cm over 2 metres or so? You could then slide under it pretty easily.
