Alright folks,
What do you use for working under your ride on mowers etc ?
I've had a mare this weekend working on an Etesia hydro 100 evo, I struggled at first ot get the ffing blades of then managed to wedge a woodruff key in the spindle housing, long story short, the deck came off and I fixed the problem, but it took hours and it was pouring down, sunday wasted and all I could use was the ramp on the back of our van to raise the deck to do the work.
Is there a way of doing this preferably not one that burns a hole in me pocket ?
Cheers all
  • Replies 25
I have a frame that goes under the front wheels and then you push it down and it lift everything right up, as if the machine is doing a wheelie. I'll get some pics at weekend if I go down yard.
Seen 1 of those on Flebay, they don't look very strong ?
They are spot bloody on mate.
Are they really, cool, I will look into getting one of those I think.
Anythings gotta be better than the comedy show we had on sunday.
Cheers
you could get one of the lifts using four jacks
there are varios ebay companys selling versions of these for different money
Car Lift Platform 3m Long x 1.8m Wide x 3' High (1.95m between post) (Y650) - Frost Auto Restoration Techniques Lift Platform 3m Long x 1.8m Wide x 3' High (1.95m between post)&catID=&frostCat=&frostSubCat=&subCatID=
or drain all liquids and put it on its side
you can lift some of them or pull it over with your van and a load of tyres on the ground
or you could lift it up and stick it on four axle stands
halfords do a set with varios bits of kit quite cheap
change it for a husky ride on with a front mounted deck as these tilt through 90 degrees to get to the blades for maintenance and cleaning.:thumbup1:
Car Lift Platform 3m Long x 1.8m Wide x 3' High (1.95m between post)*(Y650) - Frost Auto Restoration Techniques Lift Platform 3m Long x 1.8m Wide x 3' High (1.95m between post)&catID=&frostCat=&frostSubCat=&subCatID=
1,Too expensive
2,Done this before with a different machine and fooked the suspension/chassis whatever on the lower side wheels
3,It ways a f...ckin tonne mate.
I just want something quick and relatively easy to use.
Defo go for my option. Any way you can link me to he one you have seen on fleabay so I can tell you if it's the same thing?
