I regularly hang a 660 on my black diamond. The petzl isnt quite so strong, but they only cost about a fiver so if it lasts a year I'm more than happy. Normal length saw strop does me fine, 150 cm when extended, the bungee type with a steel ring near the saw end. The steel ring clips into the clipper, the biner end stays attached to the red ring all the time.
Dont mind a bit of arse bashing myself, but I find with the saw clipped up high and slightly aft of hip it doesnt get in the way too much.
I hated the idea of using the red clip so i used the side stuff sure enough it started to fail so used the back red one after a few weeks though it seems second nature to use the red clip,you just need a longer strop! Its by far the most agile and comfy harness i have used ,its major down fall imo is the elastic that holds the leg loops in position causes a wave of nausea when it gets snagged and slaps your arse.
I would look at the duo 3 though if looking for a harness.
cool, well wills tm is in the van, so i might go have a play in the oaks outside in a bit, mess up his adjustments for him :)
i did wonder if you used the metal ring on the caritool, our boss uses the caritool to hold the handle of a topper, but then he is 3ft nothing!
i had the original one complete with bridge problems, still got it back in the uk, that was ok actually, but ordering a harness tommorrow!
just seen this on the tree motion:scared1: dont think even peter has this much junk:lol:
just gonna have lunch, then off for a climb, hows best to wear the tm? i like to wear harnesses below the top of my hips, not on my lower back
Im sold! just been out to try one, as comfy as the tree magic, so why not
even tried footlocking, but it just wasnt gonna happen for fat boy :001_tongue:
