I use a small little line mug. Does the job, its compact and I can clip it onto my harness and use it to retrieve my cambium saver.
And keep your fags in it if you smoke haha
  • Replies 25
Having judged the Throw line for the ISA comps the last few years a lot of the guys and girls use Zingitt its a pretty good line the weaver is good if you need to pull a landrover out of a ditch but has way too much memory (retains its loops)
The new Stein Throw line looks promising its only just come here I think its made in Germany but initial reports are good and its a hell of a lot cheaper than Zingitt or Liros at only about £15. I also see the new Blue Stein cubes have arived same price as the old ones at about £25 but they have now fitted them with ends on the rods to stop them poking out the corners a major issue with the old ones !
We have taken one of the new Stein cube and put it through it paces and tried to make the corners go, but after a bout of football with one at Capel it held up well. :thumbup:
not sure what mine is, its yellow :confused1:, its ok, used to have it in a bucket but even after repeated use the lines memory caused it to coil and tangle up, so now its wrapped around a bit of wood. does the job :thumbup1:
