I tell you what would be very interesting...Air-spade a Beech root system after one has been felled. I wonder if it would be poss' to lift most of the root system, invert it and then study the decay....?
i'd be up for that...
This Fagus is being retained in a public park by an LA local to me.
Relatively high target area.
Has had root decay investigation, not sure which method.
Personaly IMO, a small reduction would have made me sleep easier, if i was involved in any decision to retain.
IMO you would most likely need to do this a hundred times over if you are to gather information that could in any way be considered reliable for the purposes of informing the industry as to the real characteristics of the fungus
Not that this should stop you.
It's good to do for your own information.
I like to cross section where there is rot after I have guesstimated how far I think the cavity or rot may go and look at the structural integrity etc
Good for personal learning
You need to get out more!!!!!!!!!
Only kidding,I do the same:wave:
we had a very large beach with mirrip that we reduced by 30% and tryed to retain blow over...it covered 3 gardens and took out 2 sheads and there contents ....apart from the main bowl of roots they disapeared to rotten mush stumps around 2 metres from the stem...the upturned root plate if you could call it that stank of fungus.....there was a whole line of them that nearly all had die back and where infected due to cable tels amazing instalation of cables only a few remain.
