360 digger
Dean Lofthouse
Dean,
As a landowner you can "mine" your land for your own use i.e. to extract stone for improving roadways etc. I believe that this can be done without planning aslong as no material leaves your property.
Worth looking into, as you could say the stone you are extracting is to create a logdeck for extraction.
  • Replies 31
Dean,
That is exactly what I am doing, the rock from the top will be put over the bottom half to create a firm surface as the clay layer is a nightmare
Dean
Register your Section 36 exemption with the environment agency and then you have an annual limit of 150 tonnes per hectare which you can level your site with. :thumbup1:
Environment Agency - Paragraph 36 exemption - spreading dredgings
while your on to the EA its worth checking that you have all the other useful exemptions in place so that when planners come looking you have the EA seal of approval. :001_tt2:
Dean
