  • Replies 29
I've only got wax at the moment Tommy, what oil do you use on your carvings
You should use Linseed oil ("Danish Oil" is a term used for a variety of oils, see Danish oil). Only use a "cold-pressed" or "virgin" variety of linseed oil, see Linseed oil.
Linseed oil will, in the presense of oxygen, harden, and while doing so, it expands thereby filling the pores of the wood.
Remember to dry off any excess oil from the surface of the wood within a few hours, as it will otherwise turn into a sticky substance.
You can use a paintbrush to apply the oil and a rag to dry off the excess, but remember to soak the rags in water before disposal, as they can otherwise spontaneously combust.
its not recommended treating any bird boxes,,,,but I use an organic oil on mine,,and the birds havnt had any complaints in the last ten yrs,,,,the yew will be fine,,,,,
Nice work Dean, love the ash bowl, you could also use flaxseed oil you can get it from equestrian suppliers
