Evening all.
I am no electrician but for the love of me i cant seem to have the light cable for the chipper last more than a moth or so before coming apart internally and not working! The wires all end up ripping off from the connectors (where screwed  in).
This is on the truck end.
The chipper end never comes off but that seems to be always loose and also creates a bad connection.
added together its a real pain in the ass!
Has anybody come up with a better solution?
Anyone run the wireless ones?
or any advice/ products that last?
Many thanks
The wires shouldn't rip out as the outer sleeve of the cable is locked in the back of the connector.
I've had some connectors where if you put a cable tie round nice and tight it stops it pulling back, although my current plug is a metal one I found in local ag dealer and that's been good.
Also , it helps to put bootlace ferrules on the wires as this stops them breaking individual strands at the corner of the screw clamp. Won't stop the cable pulling back though.
Thanks guys
Ive used both metal and plastic and had issues with both!
bootlace ferrules i'll give that a go as its going to get me pulled over one of these days for them not working!
Plenty of slack for turning but cant say the boys are using the correct part to connect/ pull from but surely its common sense?!
Cheers
Cheers
Show them how to disconnect chipper and see what reaction you get.
If no one has shown them there's your problem, may only be one doing it wrong.
