2 hours ago, AHPP said:
A one dog ground clearance machine in the making - I expect to see him on arbtalk touting for work sometime soon. He doesn't seem half as stupid as you've led us to believe in the past. 😁
On 25/09/2025 at 22:22, GarethM said:
Just buy a 4/5ft topper, most of us have gone Topper to flail and then regretted it, then gone back to a topper or the flail gathers dust.
I have had the opposite experience. 20+ years ago briefly used a finger bar mower on a Forsdon Power Major, then a disc mower on same tractor, then a 6ft Major topper, well built and solid. For the last 15 years I have had a 5ft hammer flail on the back of my 40hp Kubota STV40. The flails have picked up a metal shovel, a 12ft metal gate, hit 8-10 inch diameter logs in the undergrowth. None of these events have damaged to flails. Today I was flailing a paddock and had to crown raise a sycamore at the edge of it. Maximum diameter of branch was 2.5 - 3 inches. I just put the brash and branches on the ground and pulverised it with the flail. Italian made, not Chinese.
Erm, think you might be reading someone else's experience, not saying I don't like flails for the job they can do or the relatively low damages from it eating things.
Low hp tractors such as the op are definitely topper type, without it becoming tediously slow.
I will be going back to a topper with a smaller fergy tractor, my 80+ hp with a 2m flail on ground that makes a goat clench when you're 14ft off the floor doing overgrown scrub is boring.
Trying to get back to managed pastures, flying around after a bit of sheep grazing.
I've just pulled a thorn out of his forehead, presumably from going so enthusiastically face-first at his work.
  • 4 weeks later...
Morning all.  I thought it would be polite to update this thread after all the advice I received.
 I plumped in the end for a flail as I'm working in some tight areas and often up against estate railing so felt compactness and manoeuvrability trumped all.  I bought a Chapman CFM150 and although it was expensive versus some machines on the market I don't regret it in the slightest. It's incredibly well made and does a fantastic job. I certainly don't find it's slow, I've finished all my cutting for the season in a couple of mornings. Previously it has taken me days. It is definitely not too much for the tractor to cope with power wise and manages dense sedge up fairly steep banks without any trouble.
It's always good,  but so seldom happens that we hear of the final outcome of a call for guidance and knowledge.  Well done making an educated decision.  Enjoy finding more tight corners and difficult areas to work it on.
Thanks for letting everyone know and Im glad its been a success. I have a tow behind the quad flail made by chapman and i'm very pleased with it.  I guess that at 25hp, the power at the flail will be pretty similar to your setup.   Solidly built and easy to grease and work on.
