I have a lot of crooked  2.5mtr long cordwood, can you recommend a light chainsaw with 15” bar that you would suggest for cutting it into to manageable lengths to go through an old Japa 2100
processor.Preferably a Stihl or Husqvarna chain saw, many thanks.
43 minutes ago, Steven P said:
Do you have a budget in mind?
Will battery work or petrol only?
Petrol .
As regards cost unfortunately they are what they are🙀
If it has to be Stihl or Husqvarna - my little MS182 hasn't let me down yet, though I tend to go for a battery saw instead for the amount of use that one gets. If I was going for a small petrol saw again I would be looking at the 200 series though just for the slight increase in power.
The Stihl MS261C is a great saw however, new, it is expensive, although there are a few available pre-loved (used) at the right price (IMO).
GEORGECARRPOWERPRODUCTS.CO.UK
Very light, handy and powerful professional chainsaw. The electronic self-tuning engine managemen...
https://www.ebay.co.uk/p/1130082743?iid=187586474057
What saws have you got? If you haven't got a 261 or 550 then you should get one, both good general purpose saws which cut fast on a 15".
Personally I run 16" bar on 261, I'm very happy with the balance on that and see no need to go down to 15".
The big choice is whether you go for a PROFESSIONAL range of saws like Stihl MS241, MS261 etc.  These cost about £800 are solidly built, easier to replace parts, but heavier than a CONSUMER/PRIVATE saw.  Consumer saws are lighter, less robust, but are much cheaper.  For example the MS212 about £400.
You could even go as small as a MS161 which costs about £150. This would only take a 13 inch bar though. I have a few of these cheap saws and if you took after them you can get 5-10 years out of them depending on usage.  Any saw will die if you strain it or overheat it.
