  • Replies 31
Loads of compression. Removed air pipe and tried it and it's not blowing through the oil filler.
I just ain't got a clue:confused1:
i had a similar problem and it turned out to be the automatic stop. when the soleniod is broken it is pushed out and stopsthe fuel flow to th engine.
try taking it off...i think mine was two allen key bolts and see if that solves it.
hope thats some help
id say it was dirt in an injector holding it open so to much diesel so the thick black smoke may be an idea to get them cleaned and pressure tested
had a similar problem at work with a lister twin on a peeler was running fine then stopped changed filter which was blocked up. tried to start it again and all we got was a very thick back smock. injectors have been set away for cleaning and pressure testing.
just my thoughts :001_smile:
Thick black smoke is almost guranteedto be unburnt diesel, which would suggest too much diesel, whhich would lesd me to suspect that you may have govenor problems in the injector pump, but usually if the govenor is stuck open then you would just get an engine revving flat out. My knowledge of injector pumps is limited though, and it could be that if the shut off govenor goes that it goes with a large puff of unburnt fuel, so i could be off the mark. Fuel starvation in a diesel produces missing and blue smoke. Can you get it running at all, and if so does te smoke smell of diesel?
