54 minutes ago, lan said:
Please excuse my ignorance but is this wear normal, chainsaw is a year old and had moderte use?
Kind regards
Thats not the clutch , its the drive sprocket . I have seen worse ! If its a " spur " sprocket then you will have to replace the clutch drum as it is attached to it . " floating " sprockets you can just replace separately .
Rim sprockets as we call them in the trade.
Yes once the drive link bottoms out and marks the bottom of a spur sprocket with that telltale bright spot it needs replacing. How many chains have been through it in the year? I would supect an over tight chain if not more than one.
Did not know that.
Every day a school day it seems.
Yes . A floating rim as we call it . I did not want to say just rim as the op clearly was not familiar with the terms used in the trade . Spur , rim etc etc .
Edited by Stubby
51 minutes ago, Mick Dempsey said:
Did not know that.
I admit I used to run them a bit longer than that as I only had spur sprockets on less used , bigger saws. Even Stubby's floating rims will show the telltale mark the drive link makes as they wear, unlike spur drum the rims tend to explode if you run them too long.
Kind regards
lan
Thats a lot of wear on a modeately used saw.
Something isn't right I suspect.
Is it the right sized sprocket ?
Does the chain move easily on the bar ?
Is the chain over tight ?
Is the bars nose sprocket ok /free spinning ?
Alot of sprockets are harder to get hold of now , due to oregon buying up alot of its rivals, so where has ud get a rim and sprocket -more found on pro or saws of a certain cc... you will find it hard to cross over chains bars ,sprockets and stuff like that .
It was a tosser going from 058 to 050 recently on an echo 37cc pro saw
