Hi all,
I have a Stihl TS400 saw which required a new crankshaft, cylinder and piston. I also fitted a new spark plug and refurbished the carburettor.
I rebuilt the saw and when I attempted to start it, it fired up for about 30 seconds and then died. Now it won't even start. It doesn't even sound like it will start now. Any ideas or advice on what it could be please?.
Thanks.
Edited by Shaffick
Spelling mistake
5 hours ago, adw said:
Sounds like it has sheared the flywheel key knocking the ignition timing out.
Ok thanks. I'll check it out. I assume by what you said, if this is the case, the flywheel is spinning on the shaft freely when pulling to start the engine?
10 hours ago, dumper said:
Always found it cheaper to buy a new saw rather than rebuild cutoff saws just get too much abuse
That maybe the case but the saw started but now it doesn't. I'll check out the flywheel key, as mentioned previously.
17 minutes ago, Dan Maynard said:
Is 30 seconds too quick for an air leak from the rebuild to kill it? Wondering if it was pressure tested before starting, maybe it's scored up?
Hi there. Why would it score up after a rebuild?.
No it will still be tight on the shaft but the initial firing up starts to put a load on it, if it’s not tight enough, or it was not correctly seated in the key way it will shear, from what you have said it makes sense.
Thanks for that.
