30" bar very slightly bent. (1mm or less in the middle over the full 30) How to fix?
I must have been a muppet on dealing with a particularly large 5 stemmed sycamore and bent the bar which, unsurprisingly, now wanders on the cut.  When I first measured the deformation it was about 2.5 mm and by judicious use of boot and a flat surface I have reduced this to "almost" straight BUT I am somewhat concerned as to how to get it fully straight and not overdo it and bend it the other way!  To exceed Young's modulus by just the right amount I am thinking of using two plates of steel  at each end about 2mm thick and pressing down on the centre with about 100 mm wide load eg a 4 x 2" timber and a lump hammer and see if that works.  If not go up in 1 mm increments until it does
Is there a professional way to do this in a better precision engineered way?  Who would provide such a service?  I am near Oxford
See also the other post on sticky links
9C45F9A6-1BDB-409B-A945-8C894FFA4339.heic 5A596F21-F4AA-47D9-B968-16720F3DB433.heic 6948D16D-3A36-4D3D-94FB-2416454408BB.heic
If you know of a workshop that has a fly press, ask them if you can use it . " blocks of wood at each end and 1 on top of the bend and gently push down using the press . Slightly over bend a little each time until  it returns to strait .  Might be better to lift the weights off the press as well for this .
Edited by Stubby
A hydraulic press. I have one and probably use it to do as much bending back and straightening as I do bearings on it.
But you'd probably be able to do that by hand carefully levering on a hardpoint of your choice. Obviously need to bend it further to allow for spring back. Key here is little and often.
A fly press with the weights taken off would be better as you get much more feel . IMHO .
I've been using Tsu bars for a long time and first thing I do is cut the tail of the bar to release all the tension or on a daily used bar it will crack. So now the tension is gone you should be able to use as suggested by others get it back to pretty true ? Although the way Tsu and Sugi bars are tempered and finished I would't bet on it
Could you post a photo showing what you mean please.
Using the thinnest cutting disc you have, I use a dremel, put a slice at the back of the bar slot at the tail of the bar. It can have a fair bit of tension so mind your eyes as it can break a small disc
I can’t find one now but there’s at least one horrifying video out there of someone cutting an I beam (or H beam) lengthways. Lot of internal stress. Big twang. Bloke with an oxy torch gets batted into the next postcode.
