Looking for a guy with Saw Mill to cut oak slabs from a large fallena oak
Hello
Just joined the group so I hope I can post this here, if not id appreciate being shown where is appropriate. Ok so a large old oak has fallen over the winter on my land, I'm looking to hire an experienced saw mill guy to cut through the main trunk to create oak slabs for a relative to make table tops....the tree is large the main trunk where im looking fot the  cuts is will be  9-10ft in length, diameter, of the trunk is 9ft and the trunk is  28-32" in width. 32" depth. The cuts will be 2 or 3" thickness. I myself only use a 54cc for general logging and ha e ZERO milling experience. I'm based in North Wales, any help advice etc. Would be greatly appreciated.
On 26/03/2025 at 21:38, Luke50 said:
Hello
I’m not sure of any mills nearby but Tegid from supersharp might be a good shout for info. I know some lads in Barmouth who run some 4x4 Lorrie’s/mogs with hiabs who can get stuff out of most places, which might make it easier to take to a mill 🤷‍♂️. A bandsaw would be best but that size log is easily done in a day with a good chainsaw mill set up. I’d not go less than 3” in fact I’d probably go thicker for now especially the centre slab. They ain’t gonna be light to shift mind and will take a good while to dry. Stick a pic of the log up if you get the chance.
Good luck
On 26/03/2025 at 20:38, Luke50 said:
Hello
Why not post a couple of pictures of the log here?  Some advice may be given about the viability of milling.  Some of it might even be helpful…
5 hours ago, Still Green said:
Hi Luke. I have a Lucas Mill and based in Dolgellau. Not sure how far that is from you but may be able to help. More info and contact details on my website.
www.stillgreen.co.uk
Do you have the slabbing attachment for the lucas mill ?
  • 3 weeks later...
Good luck
Good advice I'll get some pics taken tomorrow and post them up...any and all input would be appreciated.
