Advice please?
My problem is a large lime tree, cut to about 3m stump in late '23, as part of subsidence damage mitigation required by insurers.  Intention was, rather than cutting to ground level, to preserve as dead stump and incidentally save some of the well-established ivy to support biodiversity - apparently common practice in ecological conservation jobs. However, the lime resprouted vigorously in the following year, not surprising I suppose from such a monster.  Insurers, told the treatment hasn't worked, have refused to pay for more and have advised keeping as part of clipped hedge - ha ha; during the season the shoots appear to grow by about a foot a day.  Not like privet!
I've cut all side 'shoots' (= small trees) and suckers back as far as I can.  The larger shoots can be treated directly with ecoplugs into cut surface.  For smaller growths, shd I insert ecoplug into the bark above the shoot?  Below it?   And is there any mileage in applying ecopods around the entire circumference (the trunk is getting on for a metre across, more at the base). If so, how high up?   Or at several levels?
Original cut surface is not re-sprouting, nor - as far as one can see - is the trunk for a foot or so below the cut surface.   Yet.
All suggestions gratefully received!
Edited by Philadelphus
Poor English.
Have a read through this^
The instructions on ecoplugs used to say that they could be applied horizontally. Ring barking might be an option. Or just keep removing the regrowth, it will die off eventually with no photosynthetic area (unless there are other limes nearby).
If done by insurance contractor job not done to correct standard. And needs redoing if contract was to treat to kill.
Other way if you want to do it your self is to drill holes in to shoots and fill with Glyphosate.
  • 5 months later...
Thanks wallyrobinet for the point about drift.  Am trying to finish off the trunk but save the ivy that is covering it, plus surrounding hedge.
Steven P, I have followed your advice over the season - with secateurs, not shears - but wouldn't advise it for a large stump.  It's a big tree (3m high and feels like about the same wide...) and shooting all over, including from side shoots.  Half a dozen-odd shoots appear for every one we cut. Much of the new growth is virtually impossible to get at through the ivy stems.  If I'd known how hard it was I'd have had more of a go at the insurers.  They refused to pay for a second go, and suggested we prune it 'as part of the hedge'.  Clearly they have NO idea of how fast a lime tree grows.  So Ecoplugs it must be.
1 hour ago, Dan Maynard said:
Why not let it grow?
because the original aim was subsidence mitigation - imagine 10 years regrowth that thing would be sucking up water like there's no tomorrow
My suggestion is buy 5l of glyphosate 360g/l
pry, scrape off ivy all around trunk at 1.5m high
drill 10mm holes at 45 degs downwards, 60mm deep, 30mm apart in a complete circle around trunk,
use a 100ml syringe with plastic tube to fill the holes nearly to top with 50% solution diltuted with preferably rain water, but hard tap water would work
May be cheaper than ecoplugs - and either method will work best in growing season, right now probably still ok, or April.
You need to take care with mixing and applying strong glyphosate
But probably still less than the original tree if it was mature with 1m diameter trunk, and at that point if it's really causing a problem it would be back to the insurance company to sort.
I'm always sceptical about felling and subsidence, doesn't seem like an equilibrium game anyway - but obviously don't know any specifics here.
yeah -  severe drought years seem to cause a lot of movement on their own.
